TIG WELDING STAINLESS STEEL TUBE
Posted: Mon Nov 16, 2009 2:42 am
by Rachel
i need help welding stainless steel 1" tubing. im using a 1/16 tungsten on a dynasty 200 75/25. everytime i start the fusion pass it burns through, does anyone know what my settings should be at? the second pass it even worse im just having a hard time over all with it. ANYONE GOT ANY TIPS? i also have to do an aluminum tube too so any help would mean a lot im trying to be the first girl at my school to get certified and this is the only thing i cannot figure out.
Re: TIG WELDING STAINLESS STEEL TUBE
Posted: Tue Nov 17, 2009 6:19 am
by mister bobo
howdy-
no pro here, but a start may be to go straight Argon at 20 with backgas. trimix or helium is also an option, though more costly, and you would have a very expensive bottle of gas waiting for the next time.
argon will also work for the aluminum. keep the c25 for your mild steel work, get a bottle of argon.
just my 2 cents!
mister bobo
Posted: Thu Nov 19, 2009 5:30 pm
by flyingnunrt
What wall thickness is the tubing?
What amps have you been welding at so far?
for 1/16" thick I'd start at about 25-30 amps for a butt joint.
very little gap. pure Argon. lanthaniated electrode sharpened to a point.
regrind electrode if you have a tip strike.
and check out the clip on how to tack SS.
