Tig Newbie, First attempt + questions
Posted: Thu Aug 20, 2015 4:54 pm
Hi all.
So i'm looking for some advice, i've always mig welded stainless so tig is a bit new to me
My setup is as follows:
Eastwood tig 200
Argon set to roughly 8LPM-4LPM roughly 15cfh- No flowmeter ATM other than bottles built in regulator, and converting units from uk to usa for easy reading for people.
Running 40amps
0.2sec pre-flow
4sec post-flow
Number 6 cup - no gas lense
No back purge
Foot pedal not used
Using 1.6mm or 1/16 2% thoriated tungstens ground to quite a sharp point
1.6mm or 1/16 308L filler rod
Practicing beads on some 304L stainless 1.5mm or 0.060 wall thickness pipe i had laying about.
Now i wasnt surgically clean in my prep, only scotchbrite pad till clean in places. Some places i did not bother at all so i knew what dirty and clean welded like.
Here's a picture of the best welds i could manage in around 1.5hours before i got hungry and went in search for food.
Weirdly enough my spot welds came out quite nice color when i used 60-80amps and survived a good hammer test
Just looking for advice and tips on getting coloring as atm mine are looking quite gray, found what i can find using google and search buttons i believe a longer post flow, gas lense and back purge will help?
Would using a smaller filler rod mean i could move quicker? if so could i use the stainless mig wire on the reel i have left?
thanks for any replys it means a lot i'll try to not annoy with silly questions
Eastwood tig 200
Running 40amps
0.2sec pre-flow
4sec post-flow
No back purge
Foot pedal not used
