Hi all,
Just joined the forum and did a search on "third hand" with no apparent results so I thought I'd put one up myself...I just made it up tonight.
It's All stainless,the pipes about 60mm OD x 8mm thick(apologies to those who haven't converted yet )so plenty of weight in it...now all I need to do is find a use for the other 9 metres
In case you're wondering,the washer is for demonstration purposes only...
Dropbear79
- Dropbear79
- big gear head
- big gear head
You mean the aluminum? I was just playing with the pulse feature. I had never used it before and I thought I'd give it a try. I had some free time and I was board.
Freddie
rahtreelimbs
- rahtreelimbs
I'm going to give a link to a few pics on Instagram a try.
https://instagram.com/p/1W_3fGjlc-/?tak ... iorwelding
https://instagram.com/p/vXOyO8DlZ3/?tak ... iorwelding
https://instagram.com/p/5hObpdjlQQ/?tak ... iorwelding
https://instagram.com/p/3083dgjlQj/?tak ... iorwelding
Gavin Melville
- Gavin Melville
These "weights" come in various sizes, 4lb seems about right. Cheap, but very hard to drill, 30 seconds with Tig torch on DC solves that.
- File 31-07-15 9 00 19 am.jpeg (52.99 KiB) Viewed 1639 times
Welder2008
- Welder2008
This is a 6"x6" square plate 2" thick, 3/8" stainless round stock as the "finger" and "legs", with 1-1/4" ball bearings as the "feet" tig welded with 625 Inconel filler...
-Tony
-Tony
- Third hand.jpg (38.78 KiB) Viewed 1634 times
- Metal_pig2001
Hi to all
and here is my gold third hand
Well brass and Silicon Bronze actually.
Regards
Ralph
Regards
Ralph
