What is this weld?
Posted: Mon Jun 08, 2015 8:15 pm
by gnabgib
- 0adce7bf80fbd4c3fbea55bccccf4c4f.jpg (66.28 KiB) Viewed 1297 times
Hmm..Colour suggests bronze?
Re: What is this weld?
Posted: Mon Jun 08, 2015 8:20 pm
by admin
Looks like bronze to me. There is a guy in the UK who posts on Instagram who does some amazing work using a torch that puts the flux in the flame. Seems to be really popular over there for for custom motorcycles
Posted: Mon Jun 08, 2015 8:59 pm
by gnabgib
admin wrote:Looks like bronze to me. There is a guy in the UK who posts on Instagram who does some amazing work using a torch that puts the flux in the flame. Seems to be really popular over there for for custom motorcycles
You mean Oxy torch? How to do...And get the 'Stack of dimes'? If gas torch, why, when tig should get a better result?
Posted: Tue Jun 09, 2015 3:53 am
by TRACKRANGER
If I'm not mistaken the flux technique is called vapor-flux. I did a heap of welding with it years ago making motorcycle accessories, clip-on handlebars, carriers, crash bars etc. We linished and polished all the steel tube components first, then used vapor-flux with Oxy-Acetylene and Bronze filler. We could get a real neat stack-of-dimes look, essentially using the same application technique as TIG with aluminium. The flame burns extremely bright because of the flux vapor, which is mixed in to the Acetylene gas line.
Posted: Wed Jun 10, 2015 6:18 pm
by gnabgib
TRACKRANGER wrote:If I'm not mistaken the flux technique is called vapor-flux. I did a heap of welding with it years ago making motorcycle accessories, clip-on handlebars, carriers, crash bars etc. We linished and polished all the steel tube components first, then used vapor-flux with Oxy-Acetylene and Bronze filler. We could get a real neat stack-of-dimes look, essentially using the same application technique as TIG with aluminium. The flame burns extremely bright because of the flux vapor, which is mixed in to the Acetylene gas line.
Ah, interesting...But what/where is the advantage over plain ol' TIG?
Posted: Wed Jun 10, 2015 10:10 pm
Oxy torch is preferred when heat isn't an issue because the whole process is more gradual, not short and SHARP like tig that results in hardness sometimes
Posted: Thu Jun 11, 2015 12:08 am
by TRACKRANGER
Yes, Mike's spot on. It was a lot more controllable.
Most of the gear we manufactured was then chromed. The result was that you couldn't see how the parts were joined together. With 'artisitc' application of the bronze, after chroming they appeared to be one single component
(And also, this was in the 70's - hardly anybody had a TIG welder in those days!)
Posted: Thu Jun 11, 2015 12:48 am
Groovy
Posted: Thu Jun 11, 2015 5:32 pm
by gnabgib
Ok, I see it all much more clearly now. Thanks
Posted: Sat Jun 13, 2015 4:04 pm
by CanMoulder
we use a Silicon Bronze or Aluminum Bronze welding rod sometimes if we are trying to add a softer pad
that is what it looks like to me . Tig weld
i'm going to have to look for that youtube video sounds cool
Posted: Tue Jun 16, 2015 3:14 pm
by d.smith
yep looks like braizing, seen it done a lot on bikes. +1 to the guy on instagram overseas that does braizing. _kamfab or something
