Stainless tig welding without argon backup?
Posted: Sun Apr 19, 2015 6:42 pm
by Nathannamaya
Just wondering if you guys have any tips for welding stainless steel without any gas backup? Or if there's some other type of way to get some type of coverage without purging. any tips are welcomed!
Re: Stainless tig welding without argon backup?
Posted: Sun Apr 19, 2015 6:45 pm
by zank
What thickness material are you using?
Posted: Sun Apr 19, 2015 6:49 pm
by exnailpounder
Solar Flux
Posted: Sun Apr 19, 2015 6:53 pm
Solar Flux B :)
Posted: Sun Apr 19, 2015 7:06 pm
by Rick_H
You could also use a piece of copper, bronze or alum as a backer clamped tight to the backside...
Posted: Sun Apr 19, 2015 7:28 pm
by exnailpounder
Rick_H wrote:You could also use a piece of copper, bronze or alum as a backer clamped tight to the backside...
Dang...you and Oscar stole my thunder :lol:
Posted: Sun Apr 19, 2015 7:37 pm
by Nathannamaya
Yeah, I've heard about solar flux, does it work any good?
Posted: Sun Apr 19, 2015 7:51 pm
by exnailpounder
Mr. Tig did a video on youtube about solar flux . Its been around for a long time so it has to work. I don't know if Jody has done a video about it but if he hasn't maybe he will. Like Rick said , clamping a strap in the back of the weld works too.
Posted: Sun Apr 19, 2015 7:54 pm
Nathannamaya wrote:Yeah, I've heard about solar flux, does it work any good?
Yes, I have some. It works. But it does leave a glass-like flux residue where you apply it. It's not like it just disappears and goes away like if you had purged it. :lol:
Posted: Sun Apr 19, 2015 8:25 pm
by Braehill
If you can get to the back side and tape it, they make an Aluminum tape that only the two outside edges have glue on them so the middle doesn't stick. There's also ceramic backer bars that work, again only if you can get to the back.
My questions would be, what are you welding and is a purge required? I would purge everything if it was simple and cheap, but most times it's neither. If your not all that concerned about corrosion resistance or if the sugaring has no affect on flow it's not that big of a deal. If the WPS calls for it then you have to do it no matter how big of a PITA it is.
Posted: Sun Apr 19, 2015 10:52 pm
by Bill Beauregard
G H Grimm makes equipment for maple syrup. They used to solder everything, lead was a concern, they now weld everything. They have machined purge boxes/ clamps/heat sinks for every joint. A small crew makes some beautiful equipment!
If you have something a consistent shape consider welding aluminum purge boxes.
