    Sun Jan 27, 2013 6:23 am
    Finland
Well it can make you look bad welder and it can definitely piss you off!
Orbital welders have to deal with problems like sulfur mismatch. Specially when autogenous welding is used. Mismatch can also be noticed by hand welding.
Mismatch will lift your puddle and it can affect to the penetration. Also undercut is usually present too. Sometimes welds will be rejected, so mismatch is not very nice thing to have around.
LnEwHEAyI40
mdT5qjtAqlI
Little bit of metallurgy too, just because I love it :lol:
Sulfur is impurity in steels. Usually steel makers try to get as low as possible, because it can affect to corrosion resistance for example. In the other hand on stainless steel sulfur tends to make machining easier. So sometimes it's ideal to have little bit of sulfur in the steel. That's why there is grades with higher sulfur content and those are usually called machining grades.
Sulfur will also affect to penetration of the weld, as it determines how metal will flow in the puddle. With very low sulfur contents it's sometimes very hard to get decent penetration without concavity etc.
-Markus-
taz
    Mon May 26, 2014 12:43 pm
    Athens - Greece
Thanks. I am a welding engineer and this is the first time I read this.
Sulphur can also increase your chances of hot cracking.
taz wrote:Thanks. I am a welding engineer and this is the first time I read this.
Taz,
The explanation is detailed in a certain Welding Engineer's Handbook you may be familiar with... ;)
taz
    Athens - Greece
I am aware of the explanation, the effects on orbital welding however eluded me (if they are however in the study material I sincerely hope none of my students is reading this :oops: )
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
I know what to blame any excessive undercut on now. Hahaha
