welded my most challenging item...
Posted: Sun Mar 29, 2015 10:54 pm
Had a filler bowl on a piece of equipment crack, needed to be sanitary welded. This bowl is a formed piece of stainless steel. If I had to guess thickness it would be around .015"... I back purged, used .040" tungsten and 6amps on a Miller Syncrowave 350LX, .035" filler.
While 6 amps is not enough to melt the filler it actually worked since the piece got fairly heat soaked quick, so with some torch manipulation and a light dab of filler it worked perfect and I was able to get 100% penetration.
