WPS for TIG states; Current and Polarity, dc, -ve to torch and I haven't seen that before. I'm doing stainless, so dc-.
It also lists Arc energy range to 2.5 kj/mm and Voltage range of 11-12V? Both of which I've never seen when talking TIG.
Kj/mm refers to your travel speed for a given setting. For tightly controlled heat input. On some ss it is ruined if held above a certain temp for too long.
Yes.gnabgib wrote:Thanks and is dc,-ve to torch possibly just a technical way of saying dc-?
Some newbie weld engineer was trying to use his new vocabulary. All he really said was, "DC-"
Ha!..Thanks Steve, confirms my suspicions. Thinks...Must remember to read between the lines.Otto Nobedder wrote:Yes.gnabgib wrote:Thanks and is dc,-ve to torch possibly just a technical way of saying dc-?
Jeff
There should be given the amperage range to follow. For example 70-90 A. That kj/mm is heat input and it's bit weird that it is given if amps are not.
Voltage does affect to the heat input as well, but usually that is not given for hand welding due to change of your tungstens hight. 10 volts refers to very small cap between workpiece and tungsten. Couple of mils or so.
Also how to determine your welding speed and track that in every single weld? Impossible with hand welding...
-Markus-
I was given all the details including the amperage range and travel speed, I just haven't included all of that here.Markus wrote:There should be given the amperage range to follow. For example 70-90 A. That kj/mm is heat input and it's bit weird that it is given if amps are not.
- TRACKRANGER
It would be great to see all of the settings. Might put everything into perspective a little better for others to follow.gnabgib wrote:
Thanks
Trevor
Well, the procedure was supplied 'In confidence' so if I gave you all the details I might have to kill youTRACKRANGER wrote:It would be great to see all of the settings. Might put everything into perspective a little better for others to follow.gnabgib wrote:
Thanks
Trevor
That said, the Kj/mm is an upper heat limit, or travel-speed quantity, as was mentioned by another. Just stick with the WPS amps, and move fast enough you don't make it black, and you should be fine.gnabgib wrote:Well, the procedure was supplied 'In confidence' so if I gave you all the details I might have to kill youTRACKRANGER wrote:It would be great to see all of the settings. Might put everything into perspective a little better for others to follow.gnabgib wrote:
Thanks
Trevor
Steve S[/quote]
Thanks, but I have to admit it's got me in a knot and I'm thinking now of making a micro rotator, because of the small size and it being a critical weld.
Jeff
Steve S[/quote]
Jeff
If you build that "micro-rotator", please share what you build!
I envision a variable-speed geared electric drill (Max 500 RPM, DeWalt makes one) with the trigger replaced with a potentiometer, for speeds as low as 5 RPM, clamped in a vise.
Without knowing the specifics of your project, this is the cheapest accurate rotator I can imagine.
Sewing machine motor. Already has a foot control, and lots are connected via belts and not built in. So easy to adapt.
I'll probably get a geared 12v servo motor, with maybe 5rpm at the shaft and gear accordingly. Need up to 26mm per minute but next question is that of the return contact. Maybe a small copper arm, spring loaded to maintain contact while the work piece is turning. I think I have the purge attachment worked out.
A little back ground on heat input may help you determine your speed needed for your weld positioner.
Just solve for "S"
Just solve for "S"
- heat input Kj.GIF (29.01 KiB) Viewed 522 times
- TRACKRANGER
"Up to 26mm per minute"?gnabgib wrote:I'll probably get a geared 12v servo motor, with maybe 5rpm at the shaft and gear accordingly. Need up to 26mm per minute but next question is that of the return contact. Maybe a small copper arm, spring loaded to maintain contact while the work piece is turning. I think I have the purge attachment worked out.
Just asking. Are you sure that's not missing a zero or something?
If it was e.g. 12mm diameter rotating at 5 RPM, the travel distance would be at least 188 mm per minute.
To get 26mm per minute with a 12mm diameter job, you would need a rotation speed of ~0.7 RPM. While I don't know the diameter being used, it somehow seems awful slow.
This 'secret' job is getting more and more intriguing ...
Trev
