Need advice on aluminum tig please
Posted: Sun Mar 22, 2015 12:04 am
by Hollywood1
Here is my first attempt at tig welding .078" 5052. I think I welded it too cold. thanks for any advice john.
Re: Need advice on aluminum tig please
Posted: Sun Mar 22, 2015 12:47 am
by Rick_H
The RH vertical appears to have a crack about half way up...is that true or just the picture?
What were your settings? 5052 flows real nice, easier to weld IMO? On outside corner joints fit up is everything....
Posted: Sun Mar 22, 2015 6:03 am
by Hollywood1
I just made an extra pass on each vertical leg messing around. No crack. Any recommendations on what you would use for settings for this material thickness. 1/16th tungsten, 1/16 filler. thanks john
Posted: Sun Mar 22, 2015 12:56 pm
Hollywood1 wrote:I just made an extra pass on each vertical leg messing around. No crack. Any recommendations on what you would use for settings for this material thickness. 1/16th tungsten, 1/16 filler. thanks john
settings on WHATmachine?
Posted: Sun Mar 22, 2015 4:07 pm
by Hollywood1
Thermal arc 186
Posted: Sun Mar 22, 2015 4:09 pm
by massacre
Looks pretty good for first attempt IMHO
Posted: Sun Mar 22, 2015 7:27 pm
by Hollywood1
Thanks . Aluminum is not easy I've decided.
Posted: Sun Mar 22, 2015 8:22 pm
by Hollywood1
Turned up the heat a little bit and was quite a bit easier to tack and welded much nicer! Could be using the wrong setup though-9 torch w. 1/16th tungsten. Here's a couple more pics. Thanks for the advice. John.
Posted: Sun Mar 22, 2015 8:28 pm
by Hollywood1
Another picture.
Posted: Sun Mar 22, 2015 11:17 pm
by Hollywood1
One more picture using step and pause. Thanks Jody, I'm addicted to tig welding.
Posted: Mon Mar 23, 2015 2:21 pm
by dirtmidget33
I have TA 186 I would start off and adjust from following settings
1/16 2% Lathanatied tungsten
7-8 cup with gas lens
85 amps (I use foot pedal)
1 sec pre-flow (I never change this setting on mine)
0 hot start (I don't use setting much, but hammer pedal on aluminum starts.
130-150 AC frequency
10-15% Wave Balance (your metal looks really new so this is where I weld new metal at. You might have to increase as needed. you might be more comfortable at 30) On a side note TA 186 % setting on this is how much it is in cleaning/positive side.
5-7 seconds post flow
Hope this helps. I hardly ever use pulse, use pedal instead. Out of curiosity what where all your settings.
Posted: Mon Mar 23, 2015 8:20 pm
by Hollywood1
I might be on to something good here! See what you think.
Posted: Mon Mar 23, 2015 8:21 pm
by Hollywood1
One more pic.
Posted: Tue Mar 24, 2015 12:09 pm
by TRACKRANGER
Hollywood1, your technique has certainly improved very quickly! Like Jody and most others mention, it takes a lot of Seat Time, but you're certainly on your way.
Trev
Posted: Tue Mar 24, 2015 12:24 pm
by Hollywood1
Thanks trackranger. I/m really enjoing welding this aluminum.
Posted: Thu Mar 26, 2015 9:28 am
by haas480
Hollywood1 wrote:One more picture using step and pause. Thanks Jody, I'm addicted to tig welding.
x2! :D
those welds look good. Hows the penetration, whats the inside of those joints look like?
Posted: Thu Mar 26, 2015 10:36 am
by Hollywood1
Pentetrated to back side slightly.
Posted: Thu Mar 26, 2015 10:38 am
by Hollywood1
Pentetration all the way through could probably turn the heat down a little.
Posted: Thu Mar 26, 2015 5:33 pm
by massacre
I like to weld aluminum too, it's definitely more challenging than steel is. At least to me anyways lol.
Posted: Sat Mar 28, 2015 11:24 pm
by 'Stang
Nice looking weld. You can learn a lot from Jody's videos. I spent two years in school and learned a lot. Then I started to learn the fine points from Jody! Lol.
Posted: Sun Mar 29, 2015 12:57 am
by Hollywood1
Thank you. This forum has really helped.
