Hollywood1
    Mon Feb 23, 2015 9:05 am
    Washington
First attempt at welding a header flange to stainless tubing. Any pointers on how much heat . 3/8 flange to .065 tubing.
Thanks John.
DSCN0737 (2).JPG (58.21 KiB) Viewed 1440 times
Hi, John,
I'll move this to the TIG forum...
Nice weld, BTW!
Rick_H
    Sat Feb 08, 2014 1:50 pm
    PA/MD
Looks good... I usually run some small 1/2" or so stitches on the outside and fully weld and polish out the inside.
I do quite a few sets of headers, turbo and an or blower it is very hard to not have a stainless flange warp. I made a jig out of thick alum to bolt the header down to then weld the stubs (beginning pieces of the header tubes). This helps a great deal, I pulse the inner with 60-100 pulses, 60amps and use .035" filler rod.
Preheating the flanges can help so you can keep the amps lower as you weld. I have found at times you still have the face the flanges after welding.
Hollywood1
    Washington
Thanks Steve and Rick! Learning more each day. Very happy I joined the forum.
Hollywood1
    Washington
Rick are you just stiching in four places? What settings on welder for the stiching? Thanks for all the help. John
