2" socket welds
Posted: Fri Feb 27, 2015 11:40 am
by joshuanaaa
Im about to start tig welding two inch sockets at work. Er70s2 wire. What kind of set up do you guys run to make sure theres no concavity and im filling the socket up properly. A qc will inspect them with a gage. Schedule 80 pipe.
Re: 2" socket welds
Posted: Fri Feb 27, 2015 12:35 pm
by Rick_H
I'm assuming your qualified if this is pressure based piping. Make sure you properly gap the fitting, it shouldn't be bottomed out, usually I use about .060-.080" ASME b31.3 calls out 1/16" pull back before welding(some guys use rings,depending on your specs, wps etc) the fillet should be as thick as your material, make sure you have proper penetration and push the rod in, I walk the cup if I have room.
What type of joint configuration will you be doing?
Re: 2" socket welds
Posted: Fri Feb 27, 2015 2:44 pm
by joshuanaaa
Joint configuration? Its a socket weld. Do you put 2 passes of 1/8 or 2 passes of 1/8 and a 3/32?
Re: 2" socket welds
Posted: Fri Feb 27, 2015 6:18 pm
by Rick_H
joshuanaaa wrote:Joint configuration? Its a socket weld. Do you put 2 passes of 1/8 or 2 passes of 1/8 and a 3/32?
Flanges can fall under a different code and specs...that was my joint configuration. I've done both as far as filler depending on joint and design/drawing.
Re: 2" socket welds
Posted: Fri Feb 27, 2015 6:40 pm
by Coldman
2" shed 80 is 0.22" wall thickness. I would use 3/32" wire. Two runs would do it. If you want to make certain do a triple run fillet (stringers).
Re: 2" socket welds
Posted: Tue Mar 03, 2015 10:45 pm
by steeldr.
a 2in.sch.80 pipe has a nominal wall thickness of .218in.,Depending on the end use, and pressure, the min.weld size would be Tx2T, T being the wall thickness, and 2T would be twice the wall thickness. or, .218in.x.436in. the pullout should be aprox. 1/16 in.( this eliminates stress on the completed weld). I would use 1/16 in. filler wire, and use a minimum of two layers,( root and cover pass with a min. of Tx2T). If you have concavity , that means you have burn through on the wall of the pipe, and this would, or could be a condition for a reject. ask you inspector before starting test, the required requirements....I wouldn't recommend walking the cup, less control and increased chance of burn through,and lack of fusion. ( my preference)......... good luck, and hope you can use some of this info.....Ron
Re: 2" socket welds
Posted: Wed Mar 04, 2015 1:44 am
by Coldman
I respectfully disagree. For a 2" sched80 socket weld joint, the amps required and size of fillet means the feed in rate for 1/16" wire is fast and also increasing possibility of silicon inclusion. Of course it can be done, I just think 3/32" is a better choice for this joint.
Re: 2" socket welds
Posted: Thu Mar 05, 2015 12:39 pm
by TRACKRANGER
Unless 1/16" is stated in the WPS, I would personally use 3/32" on that wall thickness. YMMV.
Re: 2" socket welds
Posted: Thu Mar 05, 2015 5:26 pm
by Rick_H
Coldman wrote:I respectfully disagree. For a 2" sched80 socket weld joint, the amps required and size of fillet means the feed in rate for 1/16" wire is fast and also increasing possibility of silicon inclusion. Of course it can be done, I just think 3/32" is a better choice for this joint.
agreed...3/32" is the best choice IMO.
Re: 2" socket welds
Posted: Thu Mar 05, 2015 8:07 pm
by Braehill
I'm also on the 3/32" bus.
Re: 2" socket welds
Posted: Thu Mar 05, 2015 8:47 pm
For 2" sch. 80 sockets in SS, for code work, my preference would actually be to use 1/16 for the root, so you can clearly see it go in, then cap with 1/8, in a simple lay-wire and walk. As long as you're not sparing with the root, 1/8" lay-wire will give you a weld with the correct throat.
Experiment, though... Different strokes for different folks, and all that.
Re: 2" socket welds
Posted: Thu Mar 05, 2015 9:20 pm
by Braehill
Steve,
I agree with you on stainless and do them just as you've stated, but on Carbon I use 3/32".
Re: 2" socket welds
Posted: Fri Mar 06, 2015 10:42 pm
by steeldr.
I don't disagree that 3/32 in.is a good choice for the size of the filler wire,but,1/16in. is also a correct choice.Being new at welding, 1/16 in. could also be a correct choice.....ron
