Hi,
I found some older rod, aluminum, stainless, and brass. All of them have some dirt, rust contamination and general crap on them. What is the best way to clean them up, or are they no good?
Thanks in advance,
Buggsy
- TRACKRANGER
Probably the brass you mentioned is actually bronze
Like Mike mentioned, scotch bright - but you could also probably also use emery paper if the contamination is severe. Stainless Steel Wool is also great for the aluminum.
