Dynasty 200DX - Aggressive Default Start Parameters?
Posted: Fri Jan 30, 2015 7:19 pm
I'm a relatively new TIG hobbyist, and just picked up a 2014 Miller Dynasty 200DX. In the past, I had welded with an old Miller DialArc HF, and became pretty used to the way that transformer machine worked. So far, I love everything about the 200DX, except for its default arc start.
I had been welding a lot of aluminum plate, using the factory machine settings, and a 3/32 lanthanated tungsten sharpened to a point. What I noticed was that at arc start, the tungsten was getting its tip blown off, and I was getting black soot on the aluminum. Everything I've found while searching online is related to the 200DX having hard-starts before BlueLightning was added, which is the opposite of what I was seeing.
My first reaction was that I had contaminated tungsten, so I: reground that same tungsten, tried a different angle, tried a different tungsten from the same box, tried a different box of tungsten, tried a different grinder, tried cleaning the aluminum plate more, etc. and always had the same result. The only thing that would prevent the tip from being blown off was to start out blunt. The other odd behavior was that on restart, the oxide zone always seemed twice as wide as the rest of the weld.
So today I started with a fresh tungsten, and grinder, and new aluminum plate, and went through the 200DX's user's manual. I checked out the factory parameters, and came across the fact that: with a 3/32 tungsten, in AC mode, the welder starts the arc in EP at 120 amps. This seemed excessive, so I started playing around with the start parameters in "GEN" mode. After fiddling with that for a bit, I set the welder at ".020" and just left it there.
The arc now seems to start fine, my tungsten no longer gets its tip blown off at the start, and I'm not getting any of the contamination I had before. Anyone else run into this, or is it just me? What do you guys use for your start parameters?
