Forgot the magnet
Posted: Sun Jan 11, 2015 7:44 pm
by exnailpounder
Heres a good one. Set up a fillet weld and had to lay my positioning magnet down along the backside of the weld because of a space issue. When I lit up, you should have seen that arc wander. Worse than that was....I couldn, t figure it out. I tacked the piece and was sure I removed the positioner so it had to be the welder. After trying everything in the book, I looked behind the piece and saw that magnet. Glad nobody was looking but I thought you guys might appreciate my brain fart
Thats what I get for tippin that jar one too many times.
Re: Forgot the magnet
Posted: Sun Jan 11, 2015 10:47 pm
by xwrench
As brain farts go, that's not too bad lol. At least there weren't witnesses.
Cheers.
-Eldon
Posted: Sun Jan 11, 2015 10:53 pm
by Superiorwelding
It happens to the best of us. Well, at least it happens to me. I was running self-shielded flux core and switched to solid wire and couldn't for the life of me figure out why the arc was running funny and no penatration. After a few mins...ok maybe like 10 mins, I remembered the polarity was backwards.
Posted: Sun Jan 11, 2015 10:56 pm
by dirtmidget33
Using TIG go in house for lunch turned machine off along with argon. Come back turn machine on strike an arc
No gas duh didn't turn it back
Posted: Sun Jan 11, 2015 11:02 pm
by Superiorwelding
dirtmidget33 wrote:Using TIG go in house for lunch turned machine off along with argon. Come back turn machine on strike an arc
Now that I have done more than once.
Posted: Mon Jan 12, 2015 1:21 am
Bumped the trigger on autofeed before Lunch and dumped most of a roll of wire on the ground.
Posted: Mon Jan 12, 2015 2:08 am
by Coldman
Left the full argon bottle open overnight with a perished hose o-ring. Bottle empty in the morning. [ANGRY FACE]
Posted: Mon Jan 12, 2015 12:13 pm
by Braehill
Left the welder on for a whole weekend and the other three people I work with walked by it at least a hundred times and never shut it off. Good thing the customer we supply pays the electric bill. I use a torch with a valve on it and forget quite often.
Posted: Mon Jan 12, 2015 3:24 pm
by jwright650
Superiorwelding wrote:It happens to the best of us. Well, at least it happens to me. I was running self-shielded flux core and switched to solid wire and couldn't for the life of me figure out why the arc was running funny and no penatration. After a few mins...ok maybe like 10 mins, I remembered the polarity was backwards.
BTDT ....
Posted: Mon Jan 12, 2015 4:11 pm
by exnailpounder
I know we all consider ourselves craftsmen, but its also nice to know that other people get in a hurry or are forgetful. I have left my gas on overnight and drained the bottle and now I am TOO diligent about shutting it off and coming back to weld something and frying tungsten or making a mig weld just long enough to have to get out the grinder....God I hate that.
Posted: Tue Jan 13, 2015 6:20 pm
by Wes917
Superiorwelding wrote:dirtmidget33 wrote:Using TIG go in house for lunch turned machine off along with argon. Come back turn machine on strike an arc
Kinda like, setup the back purge, get everything taped up and mounted, make sure the line is good to go. Grab torch and not turn on the purge. Grind
