My first welds... Whaddyu guys think?
Posted: Mon Dec 22, 2014 11:41 pm
by LooWee200
Never held a welding in my life and these were my attempts to teach myself TIG welding with Everlast's PowerTIG 200DV.
A couple of hours per day with a 1/4" x 2 C1018 flat bar:
Day 1
Day 2
Day 3
I only have a 110V source so I need to practice on 1/8" bars next time, for I can only go 120A max. I haven't been inside a steel supplier's warehouse ever and I was like a kid in a candy store. I just discovered that I can buy surplus steel from them after buying 5 pcs of 1/8" x 3in x 12in flats :x So I got myself 24lbs of ~1/8" steel (hot rolled, I think) plates to practice with; but I just figured that I cannot use a 6in wheel in a 4in angle grinder. It vibrates like crazy and it's not safe.
Any suggestions to maximize the use out of a material for practicing butt welds, lap joints, and fillets?
Re: My first welds... Whaddyu guys think?
Posted: Tue Dec 23, 2014 12:08 am
Seems you are going very well. Well advanced for such a novice.
Posted: Tue Dec 23, 2014 1:45 am
by xwrench
I see a definite improvement day by day. Coming along nicely. :D
Cheers.
-Eldon
Posted: Tue Dec 23, 2014 2:19 am
rule #1 for tig: take a grinding disk or a very coarse flap disc and grind the millscale off.
Check your post-flow settting. The pimple trying to pop up at the end of the welds is porosity from white-hot steel coming in contact with oxygen in the air. make sure you try to hold a arc length equal to the tungsten diameter and hold the torch there for a few seconds after extinguishing the arc. Let me guess, you're using a tiny #4 cup?
Posted: Tue Dec 23, 2014 3:43 am
by LooWee200
Oscar wrote:rule #1 for tig: take a grinding disk or a very coarse flap disc and grind the millscale off.
Check your post-flow setting. The pimple trying to pop up at the end of the welds is porosity from white-hot steel coming in contact with oxygen in the air. make sure you try to hold a arc length equal to the tungsten diameter and hold the torch there for a few seconds after extinguishing the arc. Let me guess, you're using a tiny #4 cup?
Actually a #7, gas lens, with at least 15cfh, 3/32" 2% Blue tip electrode. These welds were prior to my fixes to properly setup the welder. I had a problem with insufficient power before when using the pedal; so I went ahead and brought a 400A all brass ground clamp and ditched my 100ft 14ga orange extension (I know, using that long thin extension for a welder was stupid) for a 25 ft 10ga contractors extension cord. I'll post my pics again soon with that better setup.
Posted: Tue Dec 23, 2014 8:26 am
by jwright650
Oscar wrote: Check your post-flow settting. The pimple trying to pop up at the end of the welds is porosity from white-hot steel coming in contact with oxygen in the air. make sure you try to hold a arc length equal to the tungsten diameter and hold the torch there for a few seconds after extinguishing the arc.
Keeping the torch in place after the arc is extinguished is tough.....I find myself getting in too big of a hurry and not leaving the torch in place to keep shielding gas covering the hot puddle...and I end up with those "pimples" sometimes.
Posted: Tue Dec 23, 2014 12:45 pm
If there is zero draft you can get away with less argon flow than that. I've dialed it down to less than 10 CFH on a #7 gas lens if I keep the stick out short enough. If you have an extended tungsten stick out then you can keep it as is. Just saying :).
jwright650 wrote:Keeping the torch in place after the arc is extinguished is tough.....I find myself getting in too big of a hurry and not leaving the torch in place to keep shielding gas covering the hot puddle...and I end up with those "pimples" sometimes.
That's just a self discipline issue. :)
