ESENTI
    Wed Jan 04, 2012 8:36 am
im Esenti that I have my fronius machine, After some time in the forum i upgrade myself to fronius 1 since thank to this site
im flirting the title a good welder .I consider myself good to a respectful level . Today i was not busy so i played around
emptying the argon bottle . From 40 Hz to 200Hz at a 10Hz pulse 85% Duty cycle to 85% base current . The flow is constant
at 7 L/m. The aim was to produce nice bead and this is the result maybe is not much but im pleased since this time i focus
on the rear of puddle also so to produce equal beads . The bead is a bit wide since i used 3.2mm green tungsten that was
a bit thick for the Job of 130 amperes . ( actually it is a desirable situation when you have to do in a rather wide area as in this case ) .
ESENTI..
