rodrigoziminov
    Thu Nov 13, 2014 12:19 am
Hi all. This is my first post although i've been watching jody's videos for a long time.
This is a timing cover out of a 2013 Honda Fit. It was in a frontal crash and the motor mount sheared off the timing cover taking a couple of chunks off of it. The cover is not available from the dealership yet so we had no choice, it had to be fixed.
Basically i had to add the metal that was missing, drill a new hole for the motor mount stud and make it look somewhat decent.
I think it came out pretty good. I used a Hobart EZtig 165.
Installed and ready to go.
    Sun Sep 22, 2013 10:14 am
    Minneapolis Mn 55407
Welcome
If thats a first,good job.
Everlast 250EX
Miller 250 syncrowave
Sharp LMV Vertical Mill
Takisawa TSL-800-D Lathe
rodrigoziminov,
Welcome aboard!
That's impressive work, especially if the "165" in the welder's name is it's peak amperage. Did you pre-heat? Include a helium/argon mix? And if I missed it, what alloy filler did you use?
That's the kind of practical knowledge this forum is all about...
Mike
    Mon Dec 06, 2010 1:09 pm
    Andover, Ohio
welcome to the forum.
M J Mauer Andover, Ohio
Linoln A/C 225
Everlast PA 200
    Sat Mar 30, 2013 11:49 am
    Sweden
Welcome
You did a good repair. I did a similar repair on a Volvo engine block a while ago so I know the effort it takes to do it under 200 amps.
On pic 6 it looks like it didnt melt thru. Hope it wont take any load cus that gives massive stress concentration.
I barely could get a 9 torch in and had difficulties getting the arc at bottom of V-groove. Had to grind down and re weld coupple of times to melt thru. Drilled out and heli coiled when I wad happy with the weld.
rodrigoziminov
As far as load goes it is overkill anyway. Ive seen these engines held together by 1 bolt and not have any problems.
I used no preheat. Basically what i do is hit it first with no filler wire trying to get the AC to clean the casting a bit. By the time you are done "cleaning" it is pretty hot and you can start adding filler. It is a pain though. You have to stop and wirebrush constantly. I think i used 4043 filler with straight argon.
