Hey guys,
I have been welding for 10 uears now off and on and steadily for the last 3, I have just recently wandered in to TIG territory and it's been a while since any formal instruction and my welds look like crap. Not the bead appearance so much as the color and "texture". I will attach a few photos I took this morning. I am using a 3/32 2% thoriated electrode, hot rolled steel with the mill scale sanded down to shiny bright metal, 308L stainless filler, standard #6 cup, 17 series torch. Material thickness is 1/8 and I'm running 90 amps, pure argon at 30 cfh. This is just a few stringers on some scrap. If anyone can spot where I went wrong then by all means feel free to let me know.
- Ink5ling3r
- GreinTime
30 is way too high man. You're double at least what you should be. Too much argon is just as bad as not enough. Turn it down to 10-15 cfh and try again. Your not running a #16 or #18 cup that you're trying to fill, that #6 is 3/8" at the end of the nozzle.
- Ink5ling3r
Thanks for that, I'll give it another shot when I'm back in the shop on Monday and I'll put up those pics as well.
Do it right the first time, or don't do it at all!
Hotter and faster will help the bead flow out. You want a nice even width with the toes fully wetted into the base metal. That's really hard to do when running on the cold side. I'd personally set the machine at about 130 amps and work the pedal. You'll outrun the coverage of a regular collet body and #6 cup though, so expect some gray.
+1zank wrote:Hotter and faster will help the bead flow out. You want a nice even width with the toes fully wetted into the base metal. That's really hard to do when running on the cold side. I'd personally set the machine at about 130 amps and work the pedal. You'll outrun the coverage of a regular collet body and #6 cup though, so expect some gray.
I agree with Zank - also, out of curiosity, why are you using 308 stainless rods on mild steel?
If you have one, you can drop down to a 1/16" tungsten - you're not running enough amps to need the 3/32"
- image.jpg (63.66 KiB) Viewed 805 times
Also, you need to practice to hold a tight (~0.050") arc. Shaky hands and holding the tungsten like a Roman Candle (far, far away, lol) will get you no where fast. Prop so you can always get a clear view of the tip of the tungsten. If you can't see the tip of the tungsten, you can't see arc length to the work piece, simple as that.
Soon2GetIt
- Soon2GetIt
You may want to check out Hobart School of Welding book store on line. They have the knowledge (no doubt about it) for sale to one and all. When I got my MIG machine I bought their GMAW (MIG) book and a calculator card for each Mig, Tig and, Stick. Bought a Tig machine two weeks ago. One week ago I bought their GTAW (TIG) book. Their shipping cost is stupid high, but the the product is worth it- imho. Miller has a good GTAW booklet on their site too. Its a pdf and, goes into variables for material, electrode, gas, power, etc.
With your gas set at 30, didn't you notice the puddle begin blown around? That was my experience when trying to fix the bead with gas flow. Setting gas to about 15 is solving the gas variable for me with .120 inch thk cold rolled steel. The heat thing was dogging me too. It can be solved by getting the item being welded up of the bench. Get an air gap below what you're welding and you'll have better control of the heat. The bead formation and movement becomes more predictable. Hope this helps.
