Millerismyname
    Tue Mar 18, 2014 11:47 am
    Houston
Tacking up the neck on a fixture
Top of tank
Top of tank
What do you guys think about this? 6" alum pipe with two .080 caps and a neck in the middle...130 amps, 150hz, 70%eneg controlled with a foot pedal on a homemade turntable. Been tig weldin aluminum for 3 months and welding and fabricating about 2 1/2 years.
Millermatic 212
Thermal Arc 300gtsw w/ foot pedal
Everlast pp50
Craftsman Professional 60gal
Homemade turntable/air driven
Lg 10000 btu portable ac unit(haha)
Too many other tools to list...
Rick_H
    Sat Feb 08, 2014 1:50 pm
    PA/MD
I'd say....looks pretty damn good. :mrgreen:
Millerismyname
    Houston
this was 3 months ago I call it my starting point
Thanks Rick! It took me awhile to get it where it looks like that, if I welded for a living I'm sure I could have shortened the amount of time it took. Also, I was using a #8 cup with a stubby 3/32 gas lens with 2% lanthanated tungsten. If this helps anyone I've found that amperage and travel speed are the biggest issue with aluminum(to me) and don't be afraid to push that pedal down, a cold aluminum weld looks like fidos butt! I had a lot of bad welds because I didn't put enough heat in the puddle.
Millermatic 212
Everlast pp50
Okay, here's where the
"LIKE" button applies.
That's a very nice finished product, and THANK YOU for posting the early attempt for comparison.
    Sun Oct 27, 2013 10:57 pm
Very nice work :)
Homemade turntable? Powered? Got pics? :D
TamJeff
    Tue Dec 04, 2012 4:46 am
Nice!
    Mon May 12, 2014 12:06 am
    Downey, CA
Nicely done!!
I second the request for information on the turn table....
Glen
Millerismyname
    Houston
Internals
Internals
Outer shell was from a old miller
So there is the homemade turntable, it's a pneumatic motor with a belt that turns a pulley which turns a shaft that's connected to a piece of 1/2" aluminum plate that has been drilled out. It's rather simple and very effective. Any box with wheels could be used that just what I had available to me, the motor is around 150 from McMaster and the rest of the stuff was just scrap yards and old equipment.
Millermatic 212
Everlast pp50
Ah, an air drive motor :)
I had not considered that air could be a good choice due to adjustable air flow - cool :D
    Thu Jan 24, 2013 10:13 pm
    Eddy, TX
I never considered that either, good to keep tucked away.
motox
    Thu Nov 28, 2013 12:49 pm
    Delaware
do you control the speed with a foot pedal?
Millerismyname
    Houston
You can adjust the speed with your foot, and I do sometimes but it's really touchy. The best way I've found that works is just setting the speed with the inline air adjustment knob and speed up or slow down accordingly.
Millermatic 212
Everlast pp50
    Tue Jan 07, 2014 9:06 pm
    Elizabeth, WV
That is a very nice design! Looks like it works good.
Matt
    Wed Aug 06, 2014 12:48 am
    Melbourne, Australia
Count me in on the list of people impressed with that weld job. Really nice!
motox
    Delaware
i agree nice tool, great welds
