450dualsport
    Wed Oct 30, 2013 10:46 am
This is probably a silly question, but it is something I have wondered about. Is it necessary to purge the gas line when done welding or is it sufficient to just close the tank valve and let the gas in the line and the machine slowly leak out?
Thanks.
Mongol
    Sat Jan 25, 2014 4:56 pm
It wouldn't hurt but I'd consider it unnecessary.
dirtmidget33
    Tue May 13, 2014 5:22 pm
I was taught to
1.turn off tank
2. Purge lines
3. Back off regulator
Reason being is to relieve preasure on springs and diaphram , if it is diaphram type regulator lets the diaphram relax. Is it necessary cant say for sure but it supposed to increase life of regulator I continue to do it but very anal about tools and keeping shop clean. Job not done until mess from that job is cleaned up. Customer pays for clean up time all part of the job.
    Sun Oct 27, 2013 10:57 pm
dirtmidget33 wrote:I was taught to
1.turn off tank
2. Purge lines
+1
same here on all counts
    Mon May 12, 2014 12:06 am
    Downey, CA
+2
Glen
450dualsport
I have always purged the line just because it seems like the right thing to do. I just wasn't sure how necessary it is....
It is easy on the Mig welder, I just disengage the drive rollers and hold the trigger down until the regulator and line purges.
On the Tig welder, I understand that you are not really supposed to let the HF run for extended periods, so I close the tank valve and initiate the arc for a second and let the post flow purge the flow meter and line. Does anyone have a valve installed for purging?
RichardH
    Sun Jan 12, 2014 10:45 pm
    Chandler, Arizona, USA
450dualsport wrote:Does anyone have a valve installed for purging?
This is a nice feature of at least some Everlast TIG machines - a front-panel gas purge button. It'll run for 10-15 seconds if you don't tap it again to shutoff. I use it to prime the line during setup and bleed it when done. (210 EXT model)
Conversely, the machine's too smart to use the post-flow technique. If it doesn't see that an arc was established, it won't do post-flow.
Cheers,
