Zach_T
    Sun Dec 15, 2013 2:48 am
    North Texas
What all metals can you weld with scratch start?
If ya ain't burnin ya ain't earnin
gamble
    Mon Mar 07, 2011 1:10 pm
Any of them with an inverter machine.
    Wed Jan 22, 2014 12:00 am
    Connecticut
True scratch start without high frequency? Only steel and stainless steel. You can't weld aluminum unless you add AC and high frequency.
Multimatic 255
    Mon May 12, 2014 12:06 am
    Downey, CA
Check Jody's videos... With my "old" Miller Econo-Twin HF, it's a "scratch start" TIG or with the HF remote switch, it has HF start... It's AC/DC and HF through a spark generator. Later came the Econo-TIG, some have been using the Thunderbolt and adding a HF unit for aluminum...
Glen
gamble
Louie1961 wrote:True scratch start without high frequency? Only steel and stainless steel. You can't weld aluminum unless you add AC and high frequency.
Wrong. You can scratch start on aluminum with an inverter without HF.
With a transformer machine you need HF to get past the 0 point or the arc will go out. Not with an inverter with square wave.
