aluminum bronze
Posted: Thu Jun 05, 2014 3:17 pm
by chubbysautocenter
this is tig welded in ac on mild steel. the bead looks very bad. is this the best it gets?
Re: aluminum bronze
Posted: Thu Jun 05, 2014 6:05 pm
Nope. I've seen them almost indistiguishable from a weld.
Patience, practice, CLEAN X 3, and more patience.
I can't advise you on the "how", though. Brazing is one place I'm still an oxy-fuel/flux fan, but my stuff does not have to look good, only meet liquid oxygen service requirements under pressure. I frequently repair joints that were previously TIG-brazed, because they don't hold up to the thermal cycles.
Re: aluminum bronze
Posted: Thu Jun 05, 2014 6:25 pm
Otto Nobedder wrote:Nope. I've seen them almost indistiguishable from a weld.
I finally posted a pic. but I keep referring back to the lamp post video. I just don't see how my bead looks that bad. when I go back to dc and use silicon bronze it perfect. this ac deal and aluminum bronze thing just kills me.
Re: aluminum bronze
Posted: Thu Jun 05, 2014 7:05 pm
get a piece of scotch brite pad and wipe down the filler real good, then wipe it down with acetone. You'll be suprised how much crud comes off it. ;)
Re: aluminum bronze
Posted: Thu Jun 05, 2014 7:22 pm
Oscar wrote:get a piece of scotch brite pad and wipe down the filler real good, then wipe it down with acetone. You'll be suprised how much crud comes of it. ;)
scotch pad.. ok thanks :D
