chubbysautocenter
    Fri May 16, 2014 4:04 pm
    san antonio texas
this is tig welded in ac on mild steel. the bead looks very bad. is this the best it gets?
I HATE BEING BI POLAR ITS GREAT
Nope. I've seen them almost indistiguishable from a weld.
Patience, practice, CLEAN X 3, and more patience.
I can't advise you on the "how", though. Brazing is one place I'm still an oxy-fuel/flux fan, but my stuff does not have to look good, only meet liquid oxygen service requirements under pressure. I frequently repair joints that were previously TIG-brazed, because they don't hold up to the thermal cycles.
chubbysautocenter
    san antonio texas
Otto Nobedder wrote:Nope. I've seen them almost indistiguishable from a weld.
I finally posted a pic. but I keep referring back to the lamp post video. I just don't see how my bead looks that bad. when I go back to dc and use silicon bronze it perfect. this ac deal and aluminum bronze thing just kills me.
get a piece of scotch brite pad and wipe down the filler real good, then wipe it down with acetone. You'll be suprised how much crud comes off it. ;)
chubbysautocenter
    san antonio texas
Oscar wrote:get a piece of scotch brite pad and wipe down the filler real good, then wipe it down with acetone. You'll be suprised how much crud comes of it. ;)
scotch pad.. ok thanks :D
