    Sat Mar 08, 2014 10:39 pm
    Holley, FL
I understand that for mild steel 1 amp is needed for every .001" (thousandth of an inch). I read on here stainless steel needs 2/3rd's of an amp every .001".
What I do not know is, what's the guideline for aluminum? How many amps for every thousandth of an inch is necessary to weld it out?
    Sun Oct 27, 2013 10:57 pm
Try these online welding calculators from miller. http://www.millerwelds.com/resources/calculators/
They help get a guy in the ballpark for amps.
Wes917
    Fri Oct 25, 2013 11:45 pm
For aluminum I generally just add 25 amps to steel requirements, so for .125 aluminum I'd set at 150. Stainless I just set at steel levels. When I'm lazy ill just set the machine on max and use the pedal.
MinnesotaDave wrote:Try these online welding calculators from miller. http://www.millerwelds.com/resources/calculators/
This is a nice resource to have.
