Confused to Hell ?
Posted: Fri Aug 13, 2010 6:07 pm
Hi new to TIG ..read very new, and I read as follows
> The reverse polarity half of the A/C arc does an outstanding job of cleaning off most of this oxide ahead of the weld! How does that work? Well the reverse half of the alternating current acts like a sandblasting operation that breaks down the oxides.
Then on another site I read
When aluminum welding, the positive (+) portion of the AC welding
amperage cleans the oxides from the aluminum surface. The negative
(-) portion delivers more heat input, increasing penetration
level.Appears to be direct opposite info and certianly confusing to a newbie ?
You then add to this that on some wleders the clockwise direction increases + percent of balance and on others lincoln for example clockwise increases penetration (Neg)
But then that depend if Positive is the cleaning part or negative is ?
In short HELP as damn confused here ?
Thanks Heaps
Thanks Heaps
