    Thu Feb 14, 2013 3:25 pm
    mid michigan
still looking for used TIG welders, none of them seem to come with an argon tank. and some flat out do not have a torch.
is there any way to really test a TIG without it being set up and ready to run?
    Wed Oct 23, 2013 3:30 pm
    Palmer AK
Not really, but you could do dry runs. :lol: :lol:
Or flux coated tig rods??
AKweldshop wrote:Not really, but you could do dry runs. :lol: :lol:
even then, you won't know if the gas solenoid is functioning properly. Very important if you care at all about pre/post flow settings.
    Thu Jan 24, 2013 6:44 am
You bet. Just bring helium :D
The only tests that come to mind are to listen for the click of the gas solenoid (if equipped), and measure the open-circuit voltage with a voltmeter (should be around 50-52V for DC).
However, this won't prove it works. It can only prove it doesn't.
I'd be carefull looking at machines not in "ready to use" condition, where you can't give them a proper workout.
Jason_alex
    Fri Jan 24, 2014 1:41 pm
what about running the tig in stick mode?
Jason_alex wrote:what about running the tig in stick mode?
only proves it works in stick mode lol
