racer34
    Tue Dec 24, 2013 11:35 am
here is the ac balance Icon on my snap-on 150 t welder. am I wrong in thinking that the symbols are backwards. I thought that electrode negative was more penetration and less cleaning. the symbol seems to indicate that - gives a wider cleaning zone and positive gives more penetration. http://mail.aol.com/38252-111/aol-6/en- ... x&partId=3
    Thu Jan 24, 2013 6:44 am
Yes, you are correct. That diagram is backwards.
    Sun Oct 27, 2013 10:57 pm
I've never used yours, but if I were to guess, the readout is likely digital and pushing the "+" button increases the %
Example: 70/30 (more penetration)
Pushing the "-" button decreases the %
Example: back to 50/50 (more cleaning)
If I'm correct, it is not very intuitive.
Looks like it's marked for "More penetration" on the "+", and less on the "-"
In other words, It's not about polarity at all, but more or less penetration.
I'd have to experiment to see what it really means.
Steve - you put it in simpler terms than I did (more clear). But that's what I think too.
...I still typed it faster though :D
MinnesotaDave wrote:...I still typed it faster though :D
Are you sure? I typed it really fast. It's the corrections that took a moment... :roll:
Accuracy counts - no do-overs :mrgreen:
racer34
when you press the yellow button it moves a light until its lit up under what symbol you want to adjust. the +and- is the ac balance mode. then you turn a knob to either the left (numbers flashing)for more pos. or turn it to he right (numbers not flashing)for more neg.. each side of 0 (50% balanced) are numbers 1 thru 8. I have it set on 2(not flashing) hoping its about 65% neg. for most aluminum.
    Thu Jan 24, 2013 12:13 pm
As you say - the symbols contradicts the + / - convention of other sets - but there is no set rule on how makers mark AC balance - if you start with the digit on zero assuming a 50/50 balance try dialing it all the way down to -8 & do a quick test weld - if it's as appears it should pretty much melt the tungsten - that being the case based on other imports that use a similar system you want + 2 or 3 should give somewhere in the 60 % > 70 % ballpark your after - ( kinda makes sense ? )
