Splitting tungsten
Posted: Sat Nov 16, 2013 6:59 am
by Marc Godwin
Hi
After a number of hours on the torch I have now realized a new problem occurring. I have continuos splitting/ looks like exploded end on my electrode. Tried all types and the only one that douse not seem to be affected is the green
My welds look much better and clean but this issue of the splitting tungsten has got me beat as I have tried several different batch electrodes of the various colors an it still happens
Is it a machine set up issue
Running 135amps on peek, 85on low with about 265 on the frequency.
Re: Splitting tungsten
Posted: Sat Nov 16, 2013 8:14 am
by MinnesotaDave
Marc Godwin wrote:Hi
Lots of questions, so bear with me :)
Could you post a pic of the split end?
What size tungsten are you running? What machine? Sounds like an inverter since you have frequency adjustment.
Why are you running pulse and such a high freq? I don't have an inverter and weld on standard 60 hz with 50/50 balanced wave arc.
Pulse is not really needed on thick aluminum (looks like 1/8" stock).
What balance setting are you running?
Try more standard setup.
No pulse
100 Hz to 150 Hz freq
60% neg, 40% pos
If it's 1/8" aluminum, 150 amps or so.
Posted: Sat Nov 16, 2013 2:31 pm
by ajlskater1
Sounds like a very typical problem with a inverter machine and some of the different kinds of tungstens. That is a very common problem with 2percent thoriated (red) tungstens. A good trick I have found works is to get a peice of copper and turn your balance way down and light up on the copper till just the very tip rounds off, then turn your machine back to whatever balance you need and weld. Also when you grind your tungsten put a flat spot on the end of the tungsten, this helps a lot with 2 percent thoriated and ceriated tungsten. My favorite tungsten is 2 percent lananated they ball up very nicely, almost everytime.
Posted: Sat Nov 16, 2013 8:17 pm
by Marc Godwin
No pulse
60% neg, 40% pos
Thanks for the reply
Unfortunately I ground the electrodes to see how far the split went. And found out they vary between 3-10 mm the only way to explain how it looks is like the centre of the electrode exploded out leaving it looking all spiky :D
I am running 2.4 mm electrodes.
I am running pulse as that is what Jody does and I am self tout from watching his videos. Also I don't have a foot pedal with this Chinese Shiyo AC/DC welder
Frequency is up as I find running low frequency I tend to get a lot of arc wander and it seams to suck the filler material onto the electrode easier if low frequency. Maybe just my technique due to arc wander and thus hold too close an arc?
I run about 50/50 arc balance as I seem to also loose heat when I run to much cleaning.
Posted: Sat Nov 16, 2013 8:34 pm
by Marc Godwin
ajlskater1 wrote:Sounds like a very typical problem with a inverter machine and some of the different kinds of tungstens. That is a very common problem with 2percent thoriated (red) tungstens. A good trick I have found works is to get a peice of copper and turn your balance way down and light up on the copper till just the very tip rounds off, then turn your machine back to whatever balance you need and weld. Also when you grind your tungsten put a flat spot on the end of the tungsten, this helps a lot with 2 percent thoriated and ceriated tungsten. My favorite tungsten is 2 percent lananated they ball up very nicely, almost everytime.
Hi cheers,
I do use a piece of copper to clean the electrode but never tried udjusting the balance, you say down does that mean more heat? Sorry newbie here :D
I will try the Lananated electrodes as you suggest
Posted: Sat Nov 16, 2013 11:36 pm
by ajlskater1
Well if uou are getting long cracks it mayb from how you are cutting your tungstens to length. Some tungtens are very brittle so you need to be careful if you are using the break technique especially 2 percent lanthated and thoriated, I recommend cutting them. Sorry what I meant by lowering your balance was turn your machine to max cleaning when balling tungsten on the copper, than turn it back to penetration when welding. The normal settings I use is a balanc of 70. So that 70 percent penetration ( dcen) and 30 percent cleaning (dcep). Hope some of that helps you. And I high recomend getting a footpedal for welding aluminum.
Posted: Sun Nov 17, 2013 12:47 am
by Marc Godwin
ajlskater1 wrote:Well if uou are getting long cracks it mayb from how you are cutting your tungstens to length. Some tungtens are very brittle so you need to be careful if you are using the break technique especially 2 percent lanthated and thoriated, I recommend cutting them. Sorry what I meant by lowering your balance was turn your machine to max cleaning when balling tungsten on the copper, than turn it back to penetration when welding. The normal settings I use is a balanc of 70. So that 70 percent penetration ( dcen) and 30 percent cleaning (dcep). Hope some of that helps you. And I high recomend getting a footpedal for welding aluminum.
I would agree but it happens on brand new tungstens never cut only rounded on the end on a grinding wheel never used for anything other than the electrodes?.
I am looking at getting a proper tungsten grinder but not cheap.
Any other ideas as it is expensive to throw away the electrodes after just one run. I have tried to grind the cracks out but no so success full.
Green does not do it at all but I read you should not use green on AC inverter machine
Cheers
Posted: Sun Nov 17, 2013 1:57 am
by ajlskater1
You can use pure(green) on a inverter, I do for the xray alum pressure tanks I do so I don't risk tunsten spitting. I know you said you were running a balanced 50/50, mayb try 70/30 add more dcen so you are not putting so much heat on the tungsten from the dcep. Also try the 2 percent lanthanated those things are awesome. Hopefully that helps.
Posted: Sun Nov 17, 2013 3:14 am
by Marc Godwin
Do you suggest to cut the tungsten every time I contaminate it in the weld puddle/ filler rod? As currently I just clean it on the grinding wheel to clean all the metal off. Is this maybe the reason for the splitting?
How do I cut the electrode, do I need a diamond wheel in my grinder? I think I will need to by another grinder as I will need to permanently mount the diamond cut off wheel :lol: as I do get contamination I fair bit.
Thanks for all your kind advice.
Posted: Sun Nov 17, 2013 5:26 am
by ajlskater1
No there is no need to cut it everytine you junk your tungsten, as long as you grind it clean you are fine. I was referring to if you cut or break your tungstens in half to fit a short back cap becareful because some will crack if not done correctly. Diamond grinding wheels/ special tungsten grinders are nice but honestly not needed for most application. A belt grinder or simple bench grinders work just fine. To cut tungstens you don't need anything special, a cut wheel, side of a bench grinding stone work great. Again special tungsten grinders work awesome but not needed
Posted: Sun Nov 17, 2013 6:06 am
by NT Unique
Hi Mate
I find I get this problem it the initial ignition ark is too high. HF and high amps tend to split tungsten's. Try setting your machine so that your initial ark amps fairly low, then have it upslope over about 3 seconds. This should stop the splitting.
Why dose no one over there use Zirconiated tungsten's? They were designed specifically for welding alloy, and do an exception job of it
Cheers
Posted: Sun Nov 17, 2013 6:14 am
Hey,
I was going to ask about the Zirconated tungstens but my phone messed up. It the only one we have at work and no problems had.
Posted: Sun Nov 17, 2013 7:28 am
by Marc Godwin
NT Unique wrote:Hi Mate
Cheers
I was looking at that and my machine does not have an upslope , it only has pre flow gas and down slope
Ok I will see if I can get the zirconiated electrodes on amazon and give them ago
Cheers mate.
Posted: Sun Nov 17, 2013 7:45 am
by Marc Godwin
weldin mike 27 wrote:Hey,
Does anyone have a sepec sheet I can down load that shows all types of electrodes and specific applications.
Posted: Sun Nov 17, 2013 9:16 am
by Braehill
Go to diamondgroundproducts.com and download their free guide. And they sell good tungsten on their site also. I've never had a problem with their brand, but that's just me.
Posted: Sun Nov 17, 2013 9:30 am
by Marc Godwin
Thanks. Just checked out the site product is $30 for the packet and $88 for shipping. Need to find a closer supplier :D
Posted: Thu Dec 12, 2013 2:40 pm
by grinder
Did you get the splitting figured out? :?:
Posted: Thu Dec 12, 2013 6:31 pm
by Marc Godwin
grinder wrote:Did you get the splitting figured out? :?:
Hi Grinder,
Actually no as I have not touched the torch since that post as I was made redundant and my contract canceled at work so we have been packing everything to move home to japan..
Mining industry has taken quite a kick in the pants globally
But alls we'll as I will be building a big shed on the farm in Japan to house the tractors and combines and planters, so will give you the run down on how it goes
Ps, just received my Dynasty 200DX and have not even taken it out the box :cry:
Posted: Fri Dec 13, 2013 1:59 pm
by grinder
Sorry to hear about the job. Good luck and have a safe trip.
Grinder
