Problems welding 1/4 in. aluminum
Posted: Mon Oct 05, 2009 12:09 pm
I am having a terrible time trying to use my new HTP invertig 201 with 1/4 in. aluminum.
I need to weld two plates at an included angle of approximately 80 degrees. I first ground the two plates as shown in "A" and welded the top without pulse or filler rod. I used 3/32 gold tungsten ground to a point and straight Argon gas. The weld looked great, but I discovered it had no penetration. I could easily bend the two parts apart.
Next, I tried leaving the two ends square as shown in "B", figuring the opening would give me full penetration, but I could get a puddle between the two sides.
Next, I tried to weld the inside angle using both pulse and no pulse. The arc wavered all over the place and the tungsten tip balled up. I tried switching to the only 1/8 tungsten I had which was gray, and it still balled up and just globbed up weld, although it made the connection stronger.
I know that I need Argon/Helium mix gas and I have just ordered some 1/8 Lanthiated (S)tungsten.
Part of the problem is that I don't completely understand everything about the Pulse settings. Every article I have found, uses terminology the doesn't quite fit the HTP.
I need help!
I need help!
