pro mod steve
    Wed Mar 31, 2010 12:47 am
How far can you push the max amp rating of a air cooled torch? I've got 2 torches now 9 & 17. Been doing some aluminum at 165 amps and wondering if the 17 is way maxed out to the poin't of needing to buy another torch. If I need to upgrade can I use the 17 hose and just buy the head?
    Fri Feb 12, 2010 10:48 am
    YOUNGSTOWN, OHIO
Actually you are maxed out for the 17 at 150 amps. You can go over max rating to a point depending on how long you make your welds and how hot the torch gets. You will probably need to go to a 26 that is rated at 200 amps. Unfortunately you will have to buy the whole torch set-up as the fittings for the 17 are smaller than for the 26. Hope that helps.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
