Fillets Photos Journey
Posted: Wed Mar 20, 2013 3:43 pm
by Nils
The material is 3/32 5051 sheet and alum channel extrusion alloy unknown, rod is 3/32 4043, 3/32 2% Lanthinated, Everlast 250EX with cooler, 114 amps, a/c 165 hz, balance 30% EP, 500 hz pulse, 45% on-time, 50% background.
- Stainless table, deerskin dedicated alum gloves, TIG Finger, 3rd Hand.
- DSCN4625.JPG (124.51 KiB) Viewed 721 times
- Panel is awesome!!!!
- DSCN4627.JPG (123.29 KiB) Viewed 720 times
- 5th run and best of all. Slow to go as usual, then Heat control is still an issue as run starts to wash out.
- DSCN4633.JPG (122.86 KiB) Viewed 720 times
Re: Fillets Photos Journey
Posted: Wed Mar 20, 2013 4:09 pm
by Nils
Posted: Wed Mar 20, 2013 4:20 pm
by Nils
Here's a picture of the rig.
- Everlast 250EX with cooler
- DSCN4626.JPG (127.69 KiB) Viewed 718 times
- Me e-grinder
- DSCN4628.JPG (124.25 KiB) Viewed 718 times
Posted: Wed Mar 20, 2013 6:09 pm
by ritzblitz
So if you are having problems with heat, back off the foot pedal a little man
Posted: Wed Mar 20, 2013 8:52 pm
by ajlskater1
One thing that may help as well is to make the one piece taller, with it being that small it will easy become hear saturated..for someone learning using bigger pieces to practices is always easier because you don't have to be as quick and precise with your amperage changes, once you get comfortable than try a joint like that. It also seems,you are running cold. Aluminum welds a lot easier hot and fast so the part doesn't become heat soaked. Cold and slow doesn't work well on aluminum.
