Tig Root in 4 inch pipe
Posted: Sun Oct 04, 2009 9:36 am
by buckwheat
:lol: Hello
Having great difficulty putting in tig root pass in 4 inch schudule 40 pipe. Can you offer any tips Thanks
Re: Tig Root in 4 inch pipe
Posted: Tue Oct 06, 2009 8:01 pm
by flyingnunrt
What is the thickness and joint preparation, amps etc that you have been using?
Posted: Sat Oct 10, 2009 10:49 pm
by welder689
Do you know how to walk the cup on an open root?
Posted: Sun Jun 06, 2010 5:18 pm
by tigamajig
.what is the root opening?
.are you starting at a tack?
.amperage?.
.the size of the pipe really doesn't matter, unless there is a breeze blowing through it.
.thickness?
.bevel?
.stickout?
Posted: Sat Jul 10, 2010 6:07 pm
by speen
here's how i do it.
first of all i would just like to mention that i weld with the workpiece in a vertical position, turning it around with a rotary table.
- first of all i make sure that the bevel nose is ~0, this makes for easier penetration.
- then i clean of all the parts using acetone or something simular.
- i tack the pieces together with a 3.2mm root opening. i just use a 3.2mm fillerwire.
- with the piece tacked up i place it on a plate with a little hole in the center, then i place my purge ontop.
- when it comes to amps, i would use something like 75 for stainless and maybe 90-100 for mild steel.
- fillerwire would be 2.4mm
- most of my heat is directed on the top part while i feed wire also at the top. i then drag it down to the bottom part.
- when i've completed the full 360 degrees i overlap about 10-15mm just to eliminate any lack of penetration.
Posted: Wed Oct 06, 2010 5:11 pm
by OrbitalX
speen wrote:here's how i do it.
Man ! i could have fun welding beside you.
