rahtreelimbs
    Mon Jun 14, 2010 10:39 pm
When using a 1/16" tungsten over a 3/32" is it preferable to adjust the AC balance to put more heat on the work piece so as not to burn up the tungsten ???
StephanusThie
    Tue Dec 14, 2010 1:55 am
correct, but you need to turn down the amps, maximum at 150 amps, balance at 68%. got it from miller handbook.
Miller Syncrowave 250 DX
Hypertherm Powermax65
Agreed.
I'll take the arc balance to 80% if the aluminum is really clean and I can wire-brush short sections right before I weld them.
