TIG grounding concept for small parts. What do you think?
Posted: Tue Feb 21, 2012 4:18 pm
Have been thinking about this for a little bit. Kind of a pain to ground a vise grip to small parts for TIG welding. Often times the clamp and cable is heavier than the part and wants to move around, even fall off the table. Also, the ground clamp is often in the way when welding small parts.
What do you think of this? It's a steel swivel base I pulled out of somebody's trash can. It has a rod all the way through, so should complete the circuit. Bearings are metal, so that shouldn't cause a problem. I'm going to weld a rod away from it for the ground clamp.
I figure tack the vise grip in this position and I'll be able to articulate the part pretty good.
Thoughts? See any issues using it?
*the spring clamp is just there to show placement of the vice grip that will be welded to the swivel plate
