ekbmuts
    Mon Nov 27, 2017 11:48 pm
    USA
I'm looking for a way to clean up my aluminum welds without marring the weld itself or the surrounding material.
I currently use a stainless wire wheel on an angle grinder but this tends to be too abrasive.
I just want, in a way, to "polish up"my weld without actually making it gleam.
Flap discs are out because they're too abrasive. Ditto grinding wheels.
Anyone know of a really soft stainless steel wire wheel that would accomplish this?
I use stainless discs, but you have to use the non-knotted type of wheel. Like this: https://www.amazon.com/Stainless-Steel- ... B07Q3654TC
Don’t use this type: https://www.harborfreight.com/4-1-2-hal ... 91282.html
If you have the correct type of machine, these work really well too: https://www.aaabrasives.com/walter-13m4 ... gKl-PD_BwE
Jack Ryan
    Wed Mar 24, 2021 10:20 pm
    Adelaide, Australia
cj737 wrote: Sun Aug 25, 2024 8:38 pm If you have the correct type of machine, these work really well too: https://www.aaabrasives.com/walter-13m4 ... gKl-PD_BwE
Would you mind posting a picture of this? I'm interested to see what you are suggesting.
I guess some backyarder did their security as I'm blocked from simply looking.
Sorry, you have been blocked
You are unable to access aaabrasives.com
Thanks
Jack
There you go, Jack
Jack Ryan
    Adelaide, Australia
cj737 wrote: Mon Aug 26, 2024 12:59 pm There you go, Jack
Thanks for that. I'll see if I can find a stainless version to try.
Jack
ekbmuts
    USA
cj737 - Thanks for some solid recommendations. Aside from the one that you said NOT to use, I hadn't seen either of these options. But both look like they'll do the trick. That knotted one that you recommended to not use - ouch! Man, that would scratch the hell out of aluminum!
Ever tried brass by the way? As in brass wire wheels?
Jon
ekbmuts wrote: Tue Aug 27, 2024 4:15 pm cj737 - Thanks for some solid recommendations. Aside from the one that you said NOT to use, I hadn't seen either of these options. But both look like they'll do the trick. That knotted one that you recommended to not use - ouch! Man, that would scratch the hell out of aluminum!
Jon
I have. I prefer stainless. I find brass wheels throw fibers way too much and they dont really do as nice a job overall as stainless brushes in my opinion.
Another cheap and productive option is the stainless "toothbrushes" youll find in the Local Welding stores. There are carbon steel and stainless versions of both. I only buy the stainless ones because they can be used on stainless welds (removes the color while weld is hot) and for cleaning aluminum. I spend a LOT of time these days with motorsports stuff or marine stuff and it seems I weld more ally and stainless than anything else.
https://www.amazon.com/Stainless-Masonr ... aafd5e5f5d
ekbmuts
    USA
Perfect! Thanks much!
Timmy_Tiggs
    Thu Sep 19, 2024 8:13 am
We use orbital sanders. If there is heavy excess, I remove that with an angle grinder.
Then I use an orbital sander, starting with a course grit and finishing with fine grit.
From experience, 120 grit is fine enough for aluminum panels to be sent out to be anodized.
We use wire wheels for stainless. When I've tried to use a wire wheel on aluminum in the past, it tended to etch dirt into the aluminum -- which I removed with an orbital sander.
