Weld Puddle looks nice but after that filler....
Posted: Wed Jul 19, 2023 9:09 am
So I use a machine that was set up before I ever made it to this company and those settings have always done me well. I have a few aluminum molds to weld so I sat down yesterday and got started. I noticed that I was out of argon so we replaced it. I cleaned my metal (lazily using the torch and a tad of pedal as I normally do) and began the process of welding. I noticed that the area I'm used to seeing where the torch and argon kind of clean the area outside the weld area was significantly smaller now but I decided to push through. I felt like I wasn't getting through the oxidation layer but hey, i'm new and wanna see what happens. Horrible choice. Dont do it.
The question I have is why is the outer area of the weld significantly smaller than usual with 0 changes to the settings?
Why do I get a nice weld puddle but when I dip my filler rod it becomes a dingy grey and appears as though the arc is just stirring it around?
For the last question I did remove my ground clamp from the steel table and used my grinder to make sure I had a good connection.
I'm still new so be easy on me please.
