I have a little project on my hands where I need to weld a SS bung for a back pressure sensor to a down pipe. The pipe looks to be plain steel or a low quality SS. it has traces of surface rust so I'm not sure. So is this the case where I would use a 3xxL filler rod?
Sometimes SS will have rust on it from carbon steel contamination Either from tooling or steel that is around it. That would mostly show up on the surface. Try putting a magnet on it. Most SS isnt magnetic, that is not 100% cause some SS is magnetic.
Im pretty sure you could use almost any SS rods to weld it.
Welding everything from the crack of dawn to a broken heart.
Use a 309L stainless rod.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
