To bevel or not bevel
Posted: Tue Jan 03, 2023 12:35 pm
by bruce991
When welding a T joint should I bevel the edge of the intersecting piece to get the strongest weld strength? I am using 3/4 inch thick and sometimes 1 inch bracing mild steel to thick wall square tube. I would think root pass in a pocket created by beveling edge of the one piece would lend itself to more strength than just butting up the two and create a fillet weld. Am I correct? Thanks
Re: To bevel or not bevel
Posted: Wed Jan 04, 2023 10:15 am
You are correct. Beveling both sides to leave a land is often required when welding fairly thick material. If not required, it certainly makes penetration a lot easier.
If you welded a short practice piece without a bevel, and one with, then cut/etch to examine the penetration, you’d see clearly the differences.
Posted: Wed Jan 04, 2023 7:03 pm
by bruce991
Thanks, I kind of felt the same way.
