Suggestions needed for intake manifold repair
Posted: Wed Jan 04, 2012 11:23 am
I've got an old Fenton cast aluminum intake manifold for a Chevy 235 Inline 6 that I've had to grind away at to get the headers and intake to fit the head properly. The intake has a water jacket underneath it to help with heating. I was a little worried that my grinding might eat into the jacket, but it seemed good until I started poking at a little discoloration with a probe. Turns out there was some sand inclusion in the casting that opened up a hole in the jacket about 1/8" diameter. I'd like to plug that sucker up, but I don't want to destroy the manifold in the process, so I figured I'd ask for help before I dive in.
I've got a Millier Dynasty 200DX that I've welded aluminum with before with varrying amounts of success. Best thing I did was repair a broken step on a Mack truck. I also welded up a license plate bracket on a hardtail motorcycle that's still holding together after 3,000+ miles, so I think I can pull this repair off.
I know I will probably need to preheat the manifold (I was thinking 200 - 250 degrees), but what the heck should I set my machine to?
I'll be honest, I bought the Dynasty a few years ago and just started using it - I had no idea what it could do until I started poking around on here and actually read the manual (crazy idea, huh?). So I don't know where to set the pulser or anything like that. I don't have any Helium and probably can't get any anytime soon (work is over the top busy).
Thanks for the advice,
Jay
Jay
