Jakedaawg
- Jakedaawg
I am not sure which Pyrex I have. Probably furick? As I bought them from Jody site. They are fragile. I only use them when using a mirror. Like on the back side of a bracket where you can't see straight on. It's not like you are really looking through the cup, it's more the extra lighting on the weld area. At least in my small experience.
i havn't used them, but was looking at them not long ago.stekay wrote:Anything to chose between the Edge or Furick Pyrex/Gas lens set ups? Cost, durability, performance?
furick are a bit of pain as you need their gas lens, where as edge has adaptors so it fits on CK gas lens (i assume other brands as well). i think the edge system is better. plus edge has a massive range of cups. tempted to get some of their rectangular cups to fit in tighter places.
Furick cups fit any 3/32 gas lens. He used to sell a special Miller lens with a groove for the o-ring, but has since abandoned that and moved to CK lenses, which they always fit anyways.tweake wrote: i havn't used them, but was looking at them not long ago.
What torch do you have/use? Buy the correct insulator and lens, and the Pyrex cups are pretty universal at that point.stekay wrote:Thanks all, it's a bit complicated getting your head wrapped around all the options for various torch sizes as well.
https://weldmongerstore.com/collections ... 20-torches
his web site shows you still have to use the modified lens for the glass cups. its only the ceramic cups that screw onto other gas lens.cj737 wrote:Furick cups fit any 3/32 gas lens. He used to sell a special Miller lens with a groove for the o-ring, but has since abandoned that and moved to CK lenses, which they always fit anyways.tweake wrote: i havn't used them, but was looking at them not long ago.
He has started machining his own lenses to mimic the Millers he used to resell. His pyrex cups will fit any gas lens. The difference is the o-ring has a special "slot/groove" with his new (and old Miller) lenses. Even Jody sells/uses CK lenses with the Furick pyrex cups.tweake wrote:his web site shows you still have to use the modified lens for the glass cups. its only the ceramic cups that screw onto other gas lens.cj737 wrote: Furick cups fit any 3/32 gas lens. He used to sell a special Miller lens with a groove for the o-ring, but has since abandoned that and moved to CK lenses, which they always fit anyways.
ok, so i can't make head or tail of what you just said.cj737 wrote:He has started machining his own lenses to mimic the Millers he used to resell. His pyrex cups will fit any gas lens. The difference is the o-ring has a special "slot/groove" with his new (and old Miller) lenses. Even Jody sells/uses CK lenses with the Furick pyrex cups.tweake wrote:his web site shows you still have to use the modified lens for the glass cups. its only the ceramic cups that screw onto other gas lens.cj737 wrote: Furick cups fit any 3/32 gas lens. He used to sell a special Miller lens with a groove for the o-ring, but has since abandoned that and moved to CK lenses, which they always fit anyways.
so looking at jody site it actually has a pic/video which shows the difference.
9,20 style water cooled torches the lens fit the o ring at the back of them. no mods or kit required.
the 17,26 style air cooled torches require a conversion kit which has a o ring slot cut into them, something the CK stubby conversion kit doesn't have. jody sells furick conversion kits for 17,26 torches.
it simply means for 17,26 torches you need the furick lens, for 9,20 torches you can use any lens.
i think edge gets around that issue by having a screw on adaptor which fits any lens.
I've never tried the Edge cups (I think those are HTP...at least I recall getting some ads from HTP for those cups). But I do love me some Furick cups. When I need the increased shielding, I use the ceramic 10 and 12 almost exclusively, but only because those suit my needs and I don't have much reason to use the larger ones. Never had an issue with the Furicks. They work perfectly and they last. Can't ask for much more than that.
