Threaded or through-hole fixture plate?
Posted: Wed Feb 03, 2021 8:08 pm
by Lippy
I'm gonna order a fixture plate. What is your preference - threaded or through-hole, and why? Thanks!
Re: Threaded or through-hole fixture plate?
Posted: Wed Feb 03, 2021 9:29 pm
Depends entirely upon the size, composition and purpose. If you need to hold small parts, threaded 1/4-20 on 2” centers for a 12” square plate is what I would use.
If you go larger, and want something more flexible, 18” square or larger, and 5/8” through hole on 2”-4” centers. I’d use a minimum 1/2” thick piece of aluminum. Through hole fixture plate also needs “feet” to lift it off the table.
Posted: Wed Feb 03, 2021 10:54 pm
by Lippy
I'm going to order the Crummy plate. Really nice and the price seems reasonable for what it is. Jody uses one on some of his videos. It is14 x 16 x 1 with either 5/8" through holes or 1/2-13 threaded holes, 2" on center. With the latter, I could also pick up one of the Amazon mill hold-down kits.
https://crummywelding.com/shop/ols/prod ... ture-plate
