2021 Everlast Powertig 210EXT AC Welding Problem
Posted: Tue Jan 26, 2021 12:08 pm
Hey everyone,
New to the forum, long time follower of Jody on YouTube. I have a small fabrication shop in Roanoke, VA called Lift Arc Studios. Ive been welding for almost 15 years, mostly MIG, but have about 5-6 years of TIG welding now. I mostly weld mild steel between 16ga to 1/4in and aluminum of similar thickness.
I recently purchased the Everlast Powertig 210 EXT for my shop. The TIG I was using before that was a Miller Dynasty 210 which was on loan through a Miller demo program. It wasn't the DX version so it felt a little too "dumbed down" for my liking and having looked at the pricetag of the 210DX, i started looking at more affordable options...starting to wish i just bit the bullet and went with the blue team.
For context, the following problem never happened with the miller plugged into the same outlet as the new Everlast.
I made a video explaining the problem and I've already reached out to Everlast directly but I figured I'd cast a wide net and post something here too.
In short, the problem im having is when initiating the arc on aluminum. Once the arc starts, it sputters, wanders, cracks and pops until eventually smoothing out. Ive already checked the gap on the HF electrodes but i dont think thats the problem anyway being that the arc is in fact coming on. The base metal was wirebrushed with a new brush and cleaned with acetone. The 4043 filler was cleaned with acetone. The ground clamp was clamped directly to the work piece. The 3/32 purple tungsten was sharpened then balled before welding using 60% cleaning for a few seconds on a scrap piece.
Heres the video: https://youtu.be/-GSkXB-anDE
Thank you for any and all help. I cant seem to find any other examples of this happening on the web. This is the newest model and I dont believe many have the 2021 model yet. I pre-ordered it...
Cheers,
Tay
Lift Arc Studios
Roanoke, VA
Cheers,
Tay
Lift Arc Studios
Roanoke, VA
