TIG Welding Aluminum with DC?
Posted: Sun Nov 13, 2011 11:02 pm
by Ultralow787
Is it possible? I realize AC is preferred and recommended, but if AC is not available, can you use DCEN? If so, would you still want a balled tungsten?
Our Lincoln V350 Pro machines do not have AC capability, but I would like to practice on aluminum plates.
Re: TIG Welding Aluminum with DC?
Posted: Mon Nov 14, 2011 12:05 pm
by turbo388
Try it and see what happens. LOL
It just melts a giant wad of aluminum, hidden underneath a big bubble of oxide and it's impossible to work with with the oxide present. That's what the AC is for, prevents the oxide from covering the puddle.
Posted: Mon Nov 14, 2011 8:22 pm
by jpence38
You can tig weld aluminum on a dcen polarity, but you can only do it on very thick aluminum that has been cleaned very very, and I mean very good. Also, you will need to use an argon/helium mix shielding gas and a BIG tungsten for the high current. It may be good to just mess around with, but it is not recommended. Have fun
Posted: Mon Nov 14, 2011 9:14 pm
by Ultralow787
Thanks guys! Not the answer I was hoping for......but I'm sure you are right. I guess using an old AC buzzbox won't work either? Assuming i could rig up the torch and gas supply for the argon?
Posted: Mon Nov 14, 2011 9:46 pm
by jpence38
You would need some kind of high frequency arc starter/stabilizer with the AC.
Posted: Tue Nov 15, 2011 10:48 pm
by Ultralow787
Thanks Jim,
I thought that was the case, but hoped for something different! LOL
