Is it possible? I realize AC is preferred and recommended, but if AC is not available, can you use DCEN? If so, would you still want a balled tungsten?
Our Lincoln V350 Pro machines do not have AC capability, but I would like to practice on aluminum plates.
Thanks
Ultralow787
- Ultralow787
Hobart 210 MVP MIG Welder
Try it and see what happens. LOL
It just melts a giant wad of aluminum, hidden underneath a big bubble of oxide and it's impossible to work with with the oxide present. That's what the AC is for, prevents the oxide from covering the puddle.
You can tig weld aluminum on a dcen polarity, but you can only do it on very thick aluminum that has been cleaned very very, and I mean very good. Also, you will need to use an argon/helium mix shielding gas and a BIG tungsten for the high current. It may be good to just mess around with, but it is not recommended. Have fun
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
Hypertherm Powermax 85
Miller Digital Elite
JD2 Model 32 Bender
Oxy-Gas Torch outfit
Generac XP8000E Generator
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
Ultralow787
- Ultralow787
Thanks guys! Not the answer I was hoping for......but I'm sure you are right. I guess using an old AC buzzbox won't work either? Assuming i could rig up the torch and gas supply for the argon?
You would need some kind of high frequency arc starter/stabilizer with the AC.
Jim
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
Millermatic 252
Dynasty 200DX
Maxstar 150 STL
Spoolmate 100
JD2 Model 32 Bender
Ultralow787
- Ultralow787
Thanks Jim,
I thought that was the case, but hoped for something different! LOL
