daniel_coursen
- daniel_coursen
I’m running a Lincoln Ranger 250 with the chopper set up. The machine had a touch start tig setting and I want to get a torch set up off that machine. Any recommendations for the simplest most practical set up there ? The machine has a plug for remote as well just unsure of the best set up without buying the high frequency box for it.
The simplest setup is just a torch and cable, clip your stick stinger on the cable end and scratch start.
That's what I do on my miller bobcat 225nt. It doesn't have tig setting.
- Granddaddy
I am a little embarrassed to ask but can someone explain what the chopper does?daniel_coursen wrote:I’m running a Lincoln Ranger 250 with the chopper set up. The machine had a touch start tig setting and I want to get a torch set up off that machine. Any recommendations for the simplest most practical set up there ? The machine has a plug for remote as well just unsure of the best set up without buying the high frequency box for it.
I'm no authority on the subject, so here's Lincoln's explanation (page 4):Granddaddy wrote: I am a little embarrassed to ask but can someone explain what the chopper does?
https://www.lincolnelectric.com/assets/ ... /nx130.pdf
looks like a really crude method of control.MinnesotaDave wrote:I'm no authority on the subject, so here's Lincoln's explanation (page 4):Granddaddy wrote: I am a little embarrassed to ask but can someone explain what the chopper does?
Arc pig is an inline high frequency generator for adaptation of existing welders. https://www.arcpig.com/howitworks.html
- Granddaddy
Thanks Dave, I am admittedly tech illiterate and that makes me skittish of add on's like that but I can understand the attraction because the best running stick welder that I have in the shop is a little el'cheapo inverter machine that I bought for my grandson's and son in law. it runs up to 165 dc amps and has hot start and arc force for about 112 bucks on sale at amazon. I don't know how long it will last but it rums really good off 110 or 220 and runs on a generator as well as it does on line voltage.MinnesotaDave wrote:I'm no authority on the subject, so here's Lincoln's explanation (page 4):Granddaddy wrote: I am a little embarrassed to ask but can someone explain what the chopper does?
I considered the arc pig as a way to get out of buying another machine but ended up buying the sw 200 back when you could still get one for around 1100 bucks, I figured the arc pig was a gamble as to weather or not I would be happy with and it was convinced by the forum reviews to go ahead and dive in to the deep end.
