sbaker56
    Sat Feb 08, 2020 12:12 am
I thought some of you might appreciate the TIG table we have at where I work, that's a 4 foot by 12 foot slab of 1/2" thick 6061-T6 aluminum. Funnily enough 80-90% of our welding is done with using AlumaPower 350s and push pull guns which are at the other end of the building. And yes, the table draws heat out like you wouldn't believe
DavidR8
    Fri Apr 17, 2020 12:50 am
    Vancouver, Canada
sbaker56 wrote:I thought some of you might appreciate the TIG table we have at where I work, that's a 4 foot by 12 foot slab of 1/2" thick 6061-T6 aluminum. Funnily enough 80-90% of our welding is done with using AlumaPower 350s and push pull guns which are at the other end of the building. And yes, the table draws heat out like you wouldn't believe
That’s a beast!
David
Millermatic 130
Primeweld 225
BugHunter
    Sun Apr 19, 2020 12:54 pm
I just wish I had room for a table that big
Spartan
    Fri Mar 06, 2020 8:59 pm
That's a nice table. I had an AL table for years and greatly miss it since going to all steel. It was 1/2" thick, but not as big as yours. Definitely nice to have that heat sinking capability when needed and it also provided a much better ground for tricky parts. Also was nice to not have to dress it or clean it nearly as often. Only downside was how easy it was to gouge the surface when moving heavy parts around on it if care wasn't taken.
ebonymilf
    Sat Sep 26, 2020 10:52 am
Spartan wrote:That's a nice table. I had an AL table for years and greatly miss it since going to all steel. It was 1/2" thick, but not as big as yours. Definitely nice to have that heat sinking capability when needed and it also provided a much better ground for tricky parts. Also was nice to not have to dress it or clean it nearly as often. Only downside was how easy it was to gouge the surface when moving heavy parts around on it if care wasn't taken.
Well I also have one in a years pas but it have been spoil now so u need to look careful to get one OK
Sent from my TECNO KA7 using Tapatalk
sbaker56
I don't think I would have room for it at home either, although on the bright side it wouldn't rust, so I could leave it wherever it fit :lol:.
Because we don't weld much steel at work I didn't think about it but it definitely would end up gouged up pretty bad if it was used with steel a lot, but it's definitely nice for getting a good ground and not getting bit by HF because of some rust or scale you didn't notice.
