What are some good TIG welding drills for a newbie trying to learn? Mainly with mild steel. I've done Jodie's drill with a 2 inch wide coupon.
Looking for something to help step up my game.
Here's where I'm at now.
Thanks!
5vzfehilux
- 5vzfehilux
Aluminium fillets Seriously though, they will really fine tune all the aspects of tig including and arguably most importantly arc length. I think as a base and regardless of welding process, as short an arc as possible and enough amps to carry that short arc is the secret to welding.MattA986 wrote:What are some good TIG welding drills for a newbie trying to learn? Mainly with mild steel. I've done Jodie's drill with a 2 inch wide coupon.
Al is lot less forgiving on bad technique than steel and Al fillets really show this up. I always find starting a steel fillet puddle much easier than Al, which takes a lot more 'encouragement'.
Thanks for the input.
I media blast the metal to get rid of the mill scale then hit it with a flap disc then acetone. There's no mill scale.sbaker56 wrote:Clean your mill scale man looks like some contamination in those welds.
