metalmechanix
    Wed Oct 26, 2011 8:14 am
Can you tig following the torch? Making weld pool and adding filler rod as the torch is moved away from rod in stead of normal way.
    Fri Apr 01, 2011 10:59 pm
    Australia; Victoria
Hey there,
I have done this, but only in a really tight spot. The main problem is that the filler metal is going in on the cold side of the pool and therefore you may get lack of fusion.
metalmechanix
Thanks, I figured there was a good reason not to but can be used in a pinch to get the job done. I am left handed so all ready going left to right. Have practiced a little switching hands but needs more practice.
    Australia; Victoria
Hi there,
I am left handed as well. But someone has to weld the other sides now don't they. LOL :lol:
metalmechanix
true very true someone does have to weld the other side. Ha!
