Work/Ground Clamp Q's - Miller Diversion
Posted: Mon Jun 29, 2020 2:55 pm
So I've been TIG welding as a hobby for about a year or 2 now. I took some late night welding classes at a local technical center and am fairly solid on all processes. However, I have some work clamp questions that despite scouring the internet I have yet to get a solid answer to:
- If my Miller Diversion's work clamp is on the table... shouldn't I avoid leaning on the table while I weld?
- If my Miller Diversions' work clamp is on the workpiece being welded... shouldn't I avoid leaning on the piece or supporting my arm or hand on the piece while welding?
- I bought myself a weldingtipsandtricks TIG finger and suddenly have all these questions, as it appears Jody invented and regularly uses the TIG finger to prop either a finger or you hand on the work being welded... So does that mean his work clamps on the table if he's leaning on the workpiece? Or does it really not matter that you're leaning on the workpiece that also as the work clamp on it, or leaning on the table that your work clamp is grounded to?
I tacked together an entire 1/16" thick aluminum diamond plate cylinder box with my work clamp on the leg of the table I had my workpiece on, and basically leaned on the table the entire time - no shock! I'm looking to find out if that's a hazard or am I just overthinking this? For me being a fairly new beginner, TIG welding just about anything requires I prop an elbow, arm, or hand on either the table or the piece - so I'm just looking for clarity and the safest way to set up my work clamp in regards to the piece I'm working/leaning on.
Any help/answers would be greatly appreciated. Thanks in advance!
