Sorry. I'm a little slow on computer 'n things.
The area of concern is the top section with the exhaust and water passages. The big center hole is the exhaust passage. The smaller rectangular ones surrounding it are the water passages in the water jacket. I made a SS exhaust system that bolts to this machined surface and I want to seal off those water passages which sometimes leaks into the engine(small-block chevy)
Charlie
Why not just make a spacer out of .125 - .180 stainless and block it with a high temp gasket?
Might save blowing through the manifold.The water ports might be contaminated and not a lot of meat to grind away.
Just a thought.
Gary
Just a thought.
Gary
That's the stock set up and has always been a point of water an/or coolant intrusion. Marine gas engines rarely wear out. Water getting in the engine from multiple causes are the usual killers and the exhaust system contributes about half of these.
Charlie
